Looking forward to tomorrow, hopefully the single arm ohp goes according to plan.
Good luck! Still going to use the bar too?
Yeah BB ohp and db, shoulders need a pounding. They're pathetic
). I had my OHP today; My shoulders were fried by the end of it!
Yea, they do (As in the muscle itself, not you). I had my OHP today; My shoulders were fried by the end of it!
They'll get there eventually![]()
Just remember to tighten every muscle and brace your core. Do you do feet close together or wide stance?
Kind of in the middle....I figured narrower stance involved more core?
I prefer narrow stance, just allows me to stiffen up and brace my core a lot easily than wider. Also has helped me get my new numbers even if some people say narrow stance is supposed to be harder![]()
Surely single arm means more need for controlling the weight, better control, better muscle building potential
Plus you can focus on that arms technique more
kd
The single arm ohp has highlighted some weaknesses in my core/bracing technique.
I also just like doing it and find it doesn't aggravate my shoulder. Try it when you start training mate![]()
Single arm DB press is awesome. It basically highlights the fact that you can have a very strong system (in this example, "pushing") that is incredibly dysfunctional and riddled with compensations. Single arm while standing stops all cheating.
Btw, the next level is with an inverted kettlebell.
Goodnight sweet ego - I started with 8kg![]()
Nice work on the deadlifts delves, your really chasing my tail on these, I have a feeling your gonna overtake me on deads
Need to get my arse down to see ice and Dom lol
