Beta alanine has a similar power effect
BA gives the most awesome tingles on the lips!!
Decided to stop using the weight machines to work out yesterday and did some barbell squats/presses.
Can hardly move today lol, good times.
Good work
I'm on 5/3/1 at the moment also. What are you getting on your + sets? LiE likes to get around 12 reps on week 1, 10ish on week 2 and 7 ish on week 3 if I can remember correctlyPersonally I like to get heaver doing around 8-10 on week 1, 5-7 on week 2 and 3-6 on week 3.
I got my mate to come squatting with me the other day, he says that he's never going again due to it hurting too much the next day. Massive, massive gay. I've stopped going to the gym with him.
Anyone else here on 5/3/1 LiE?
Why are my reps for deads so low compared to BB/Sqauts! Is this normal for everyone else? Should I lower the weight?
Maybe I just need to MTFU and smash out more reps![]()
I've not had much off an effect from the BA in my pre workout. Just a little more energy and being more able to focus, even doubled the dose once and it never had any different of an effect.
That's because it doesn't do any of that.
Beta alanine increases (over time - most studies go in for 10 weeks minimum) the concentation of nutrients in your muscles, the end effect being lean mass and strength gains. IT also requires the 'right' dosing, too.
It does not do anything for energy, focus, etc.
3.5g daily I think is what was used in most of the studies.What's the right dosing?, i've still got some i might as well use it up.
That seems not bad to be honest. Is this your first week doing 5/3/1? Big but boring helped me a lot with deadlifting and getting better rep ranges after a few cycles.
Deadlifts can be a bit funny if you're not on form, they aren't great for doing big sets. You really have to dig deep.
Your calculated RM from the +set should be very close to your RM you enter for the cycle.
Here's my last cycle of 531 I did.
http://i952.photobucket.com/albums/ae4/mmccann722/cycle2_zps5afd31eb.png[IMG][QUOTE]
Those are some bad*** numbers! Yes I see what you mean, I done 5/3/1 before infact I think I may have brought this up before and you had a look for me! Just being over cautious (over delvis :p)
[IMG]http://i49.tinypic.com/30ctwls.jpg
http://i952.photobucket.com/albums/ae4/mmccann722/cycle2_zps5afd31eb.png[IMG][/QUOTE]
Can't really tell untill the end of the cycle but meh.
No - beta alanine gets converted into carnitive -> carnosine, so as long as you have a decent diet, it should 'work'.
Do bear in mind, you're not suddenly going to lift like Magnus Samuelsson or whatever - BA, like creatine, require at least a couple of months to make noticeable differences (against control studies).
So you might have to get more, depending on how long your supply lasts.
