- 7 Dec 2005
- Wiltshire
Taking forever for OcUK to process my 7850 RMA
Awww man lol, i know how you feel!
I had 3x 7850s faulty! Did you buy from OCUK?
I see a lot of problems with the AMD cards latley?
XFX - Customer service is very poor and slow at best
Just a suggestion or two, you may want to state that OcUK will only send a replacement from stock after 28 working days (for cards over 28 days old)
Also, According to SOGA 1979, all fixes/replacements should be done within a reasonable amount of time, so in theory, all retailers should take a max of 28 days![]()
I don't know what it is but this issue comes up a lot with RMAing to OcUK where the customer claims the card is faulty yet when the card is tested back at the store they say it works fine.
Is there another computer you could test it out on?
http://www.youtube.com/watch?v=Iu-ZB9EzEFQ
Sapphire cards usually have a 2 year warranty, unless you bought it pretty much on release, then you may still have some warranty?
I'd RMA again if you are certain the card is faulty.
Make a post in the OcUK Customer Service section, explain everything as you have here, 5UB will most likely see it, take it from there - good luck, hope you get it sorted.djferrick said:I suppose I could post it and then advise him to keep an eye it if that's the done thing ? Is it ? Or how does one broach the subject with Mr UB .
I just contacted Trading Standards about this a few year ago, they told me that items such as motherboards, graphics cards etc, should take no longer than 28 days from receiving the item.wkingsnorth said:Nelly - Under SOGA can't the manufacturers technically take as long as they like as your contract is with the seller and you didn't buy from the manufacturer?
Yes, but it's up to the seller to then sort something out
E: If you RMA'd direct to manufacturer then the above is true^^
The seller-manufacturer relationship is likely to be a contracted business relationship, and thus SOGA doesn't apply to that, only what is in the contract
