Thank god I don't have that "helicoptering" issue, would truly drive me insane and make me throw it out the window!
Wifi seems fine for me so far, no different.
Yeah, I wouldn't want to loose the battery stuff and besides, cba to root etc.
I can see htc including an option to be able to remove it from the notification tray in the next update, hopefully...........
And thank goodness that I don't really listen to music on my phone then!
Yup, it has always been the snappiest and smoothest phone that I have used without a doubt, but with JB it just got so much more snappier and smoother (probably is just an improvement in animations...) especially sense stuff. I could notice micro stutter/bits of lag in things like the play store when scrolling down or up and some other apps (very minor) but now all of that is gone and for example with eye in the sky on ICS, it was always a bit slow, took like a second to change tabs (when tapped on) or open, now it is instant. The smoothness may just be down to the difference in the screen touch/response as well now, it seems more responsive and not as sensitive when scrolling. BTW I am using 0.5x for the animation etc. timings in the developer options and stock google animation speed in nova.
Although at first the phone wasn't as smooth as it is now, seems to have gotten smoother over the last 1-2 days, I know it sounds crazy and not possible but a few others have noticed the same thing
Probably just the cache stuff?
The battery is definitely worse though! Having to charge it every 19-24 hours now and have yet to hit 4 hour on screen mark
