Picked up a nail in 1 of the 4 brand new kumho tyres I got fitted last week. Right next to the side wall too :/
In the UK?
[TW]Fox;23456238 said:You seem suprised? I regularly manage that on Motorway trips (Most of which are on the same stretch as Housey did it on, obviously).
Then drove to Romford. Didn't see you Overlagthought i should clean it, but going for a drive instead.
You can get away with using cruise driving fairly quickly - in the E60 (and I presume F10), if you drop the speed to a level much lower than you are currently travelling (i.e. set it to 30 when going 70) the car will put a pretty serious amount of brake on!You have to drive differently in that you need to balance your pace better but it's easy enough to do in roadworks too. Only stop start traffic makes it problematic or where you have very bad weather such as the massive virtually instant downpour that forced me to turn it off yesterday.
Absolutely **** myself when the car popped a boost hose due to a failed clip
very frustrating! my first time was scary, thought the turbo had let go or something
