- 18 May 2010
- London
One way ticket to snap city
This is why something like this, should not be done, by beginners without coaching.
If you injure your spine, thats it. Was it worth it?
You have a small muscle tear.
Do NOT jump straight back into heavy training. Deadlifting up to 140 to see if it works isn't the best idea. Be smart brah. No squatting or deadlifting until it's better.
Can you make it hurt by doing a strict flat backed RDL with your hands sliding down the front of your legs?
If yes, start doing these every day you train. You will start with 40kg, and do 25 reps. It's ok if it hurts here. Next day, do 60kg for 25 reps. Then 70kg, then 80kg, 90kg, etc. Add weight until you can no longer perform strict reps. Do this for 8-10 workouts and you should be fixed, .
There may be better exercises than RDLs, the idea is to move the muscle through a good ROM with a simple compound movement.
You need to find a compound exercise that bothers it. Wide stance good mornings?Aww crapWorking upto 140 was the starting point it felt uncomfortable but I didn't go heavier than that just in case. When I reach down with stiff legs running my hands down my legs as far as I can keeping a neutrol back I don't feel anything my hammies stop me going further but when I really try to stretch my hammies and my back starts to flex a little I start to feel the discomfort.
Squatting thou the last few weeks has been fine thou after doing 2 sessions of strict box squats. On Thursday I worked my way up and matched my PB of 140 with no pain then 100x10. Really don't want to stop squatting is possible, I'll try RDL with a little bit of weight.
Is it ok to still do all my assistance exercises and foam roll the hell out of it every day? My lacrosse ball should have came by nowI'm working out a new routine atm and I'll post it up in my log when finished.
Great start to the new yearI've got a competition in march as well and really wanted to break some records
I starting out a HST routine soon just to mix it up from a wendler. If you have been reading the same guides as me... huge lol at the insane amounts of protein they insist you consume (2g per pound of body weight per day!), damn![]()
I've just finished my 2nd cycle before Christmas, training 3 days a week and really enjoyed it. Your welcome to check my log for info. I have changed to a more strength focused routine now, but still follow a full body's ish style that HST uses.
Quite a few on here have done HST, it think Chomg warrior is somewhat of an expert, and inspired others.
Tips: test your 15, 10, 5 rep maxes for every exercise you want to do. This really helps give you a starting point. If you don't want to do the same routine everyday there is nothing wrong with an a/b split, i did this and made some nice progress.
The guy is a moron. Being ignorant and not realizing how bad your form is, is one thing. How on earth can you video yourself and watch that back thinking it's fine?This is why something like this, should not be done, by beginners without coaching.
lol right, so it's not your glute at allTried some close good mornings and quite wide stance ones. When I reach my max ROM and push a bit further for a second I feel it a little. Looked up some videos of RDL and seen where I was going wrong =P I tried it with my bedand felt nothing so I'll experiment with weighted GM and RDL tomorrow.
The discomfort/pain is not in my glute it's about 1" above the left one, when I push myself beyond my max ROM my back flexes a little and can feel it, it's really hard to explain =P
I've been at the gym over the festive period 3-4 times a week like normal but trying out different things. Not dead lifted for a week thou. I was speaking to a friend who is training people for a BB show and he said that it's maybe because of the mixed grip and I said that I have noticed once or twice when I'm fail a max deadlift at around knee level the bar twists a bit. He recommended starting light again and either alternate my mixed grip or stick DOH. Could this be the initial problem this happened?
Absolutely not.4x8 Regular DL
4x8 RDL (New)
3x8 Deflict DL (New)
4x8 Glute pullthroughs (New)
4x8 Close grip parallel seated rows (New) <-- Fell in love with this
2x5 Full dragonflags
3x5 Partials
Yeah he's awesome
Absolutely not.
You won't be able to control your spine in a deficit; in fact, for a lot of people the whole point of deficit deads is to pull with a rounded back.
Stick to 5 reps for regular deads, 6 for RDL. Work up from 60kg on both, only adding weight when all of your sets for the day are perfect. 2-4 weeks of this depending on training frequency.
This might sound boring, but it's not optional if you want to reprogramme your motor patterning.
The alternative is to just see if you're lucky and not worry about correcting it, and hope you don't have a massive blow out.
