I've just flashed the latest Perseus kernel v31.2 on my Note II which has Samsung's fix for the sudden death syndrome (SDS) included. If any of you have been following the S3 thread you will know that they randomly started dying. It looks like the Note II is also affected.
It is caused by eMMC failure on phones with VTU00M 16GB internal memory chips with revision 0xF1. You can check your phone with the "eMMC Brickbug Check" in the Play Store. (https://play.google.com/store/apps/details?id=net.vinagre.android.emmc_check&hl=en) Ignore the message if it says you're not affected, the type and revision is what matters.
I am running the latest RedPill kernel which says it has the fix on, I assume this will be all fine then :/
Rev1.01 (CURRENT STABLE RELEASE)
Completely Rebased on N8000 Source
Use newest and official Exynos-Abuse patch from Samsung (Thanks to AndreiLux for the additional patches re: static cma regions)
Fix Freezes for some Devices when transferring large files via USB
Fix SOD for some Devices
Change CPU Idle Settings back to stock
Remove Dynamic FSync (Ability to enable or disable FSync is still available)
Removed ROW I/O as sio/deadline/zen perform better in our tests
USB Charging Rate increased to 1700
Tweaked pegasusq for battery life (limit sampling rate in suspend)
Removed Conservative (as new tweaked pegasusq can save battery with the right settings)
Added Dynamic STweaks XML Implementation by AndreiLux (Thanks to AndreiLux)
Updated STweaks (Thanks to Gokhan Moral)
use get_random_int() to fix entropy depleting (Thanks to Jeff Liu)
Updated sensorhub driver, device sensors
SDS patch included (Thanks to AndreiLux)
. I'm going to need to flash a new recovery though as I flashed the CWM one linked from Wanam's post which is quite old, I think, so I doubt that that has the fix included.
