See my edit above. Option 9 would be much easier no?
Whats fastboot guys????
Look at the above post
The menu that comes up with "Start" & a green Android at the very topLook at the above post
Ahh ive seen that a few times
Ok i got to that screen. Using the vol up/down keys i have the following options...
Start
Restart bootloader
Recovery Mode
Power off
Which one do i need?
None leave it on that screen & just make sure your phone is connected to the PC & press 9 on the toolkit![]()
Are you guys talking about a different toolkit?
Im using **** Nexus Root Toolkit v1.6.2
Ahh no wonder we are not on the same page. Its a different toolkit.
I've installed the one you guys are talking about.
Ok....So i hit 9 on that screen and im presented with 2 options
1. Download Google Stock Image
2. Flash Google factory Image
Im guessing its option 1?
Yeah option 1 & then when its finished downloading I imagine it'll be option 2 after.
As I say though I've never done this before so learning on the fly myself![]()
Its unable to download the stock android 4.2 image
ERROR 404: Not Found
Can i download it from somewhere manually myself?
Fingers crossed this works! This should be the right one.
If not, then check at the top of the toolkit and make sure your device's serial number is displayed.
is it displayed?
http://goo.im/devs/mskip/stock/occam
There you go
or directly from google
https://developers.google.com/android/nexus/images#occamjop40d
Interesting....the one from Google is 327Mb and the other is 362Mb
