WOOOHOOO!!! Pulled 160 today (new PB) on camerauploading now
Well done
HmmmBefore people watch, I'm gonna say.
Think my form wasn't that great, however my counter argument is it's a 1RM. It was also a bit of a grind. My mate said I got it off the floor fairly quick but the hip drive part was slooooow. Regardless felt good man.
the yellow plates are 15 KG
2x15KG
4x20KG
6x5KG
+ bar.
Hmmm
a) You're in trainers
2) Your hips have lateral instabilty
iii) I'm certain that a side angle would reveal an unforgivable amount of movement in your lower back
4) That hair!
5) Ice, what is wrong with your numbering!
kd
Yea you don't want too much form break even for a 1rm, otherwise snap city awaits. Even I wasn't happy with my 255 form at the comp, and it looked far prettier than that
Good work on posting a video, I'm sure you'll benefit from our comments.
Good man.Was waiting for you to post. Okay well the first part is easily remedied. THe lower back thing well. Me and the guy recording spoke after and I said to him pretty sure my lower back was bad throughout it. My lifts aren't usually that bad, e.g. The part where I lift off the ground my hips all of a sudden go really high in the air, that never happens usually. Just exerted myself too much I guess. Will work on everything you said Cheers ice.
Hmmm
Good man.
I think it's especially important given your progression in the last few weeks to not get carried away by chasing numbers. If your form stayed tight it wouldn't be such a problem, but for it to waver so much it kind of implies that the breaks are there on lighter weights but we can't see them.
Remember that this race is measured in years not weeks.
Im getting DOMs 2 days after exercise, like leg day was Monday, Tuesday i was fine but today im struggling, is this normal? it used to be pretty much the next day for me. Maybe this is result of my foam rolling?
Mild hernia?
