- 18 Mar 2013
these kind of posts are so usefull, gonna check a lot of these out
			Is there anyway to roll back an update? My Chrome's text is all over the place on forums, its a mess
Any decent podcast apps?
I have tried pretty much every podcast app on Android and iPhone and Pocket Casts is my app of choice.
-edit- just to add, streaming podcasts often stalls Beyondpod, especially if it's a really long one and I try to seek quite far into it. I much prefer to download podcasts from Beyondpod wherever possible and play in an Podcast Player. Although the GUI is a bit ugly, it's simple and works very well:
I have to ask. If you download it in BeyondPod, so avoiding the streaming issue, why would you not play it in BeyondPod?
Yeah, you tap the top right, like the tab bit.
You think the buttons aren't big enough? I could probably hit those buttons with a toe...
You can rollback an app but you'll need the APK file of the app version you want.
Hi, I would like to put videos on a Nexus 7.
I have ripped some DVD films on my PC hard drive.
So what format from DIVX to I have to convert the film to ?
I have loaded MX Media player for playing the finished format on the Nexus 7. To transfer the films I have the special USB to Micro USB cable to upload films from a USM stick.
Personally I use BS Player, stick pretty much any file on your N7 and it'll play it - no converting required. MX probably will too
