Hi there
Swapped my gen2 GT3 25.5mm rear ARB for an Gen1 GT3 23.6mm rear ARB in my hunt to get the cars understeer/oversteer balance where I want it.
The gen2 bar on softest setting was a handful, oversteer even at turn-in, bear in mind a GT3 has more rear grip than my C2S due to it's diff and wider tyres.
I had tried a C4S 21.7mm bar, an improvement over the C2S 20mm bar but still more push than I'd like.
Installed the Gen1 GT3 bar yesterday on its medium setting, so far seems great, made the front-end a lot more confidence inspiring, just turns in better and the car feels a lot more stable in high speed turns, no doubt as the rear 23.6mm is much closer to the front 26mm bar which is set to softest. There is still initial understeer at the limit, but less than previously, add more power and it pushes a little more, more steering lock or power brings the rear. Very happy, feels much better and as it's installed on medium I can adjust either way.
Also washed and sealed car yesterday with britemax elements on top of the collonite 476s I applied last weekend, paintwork is so slippery. Had an epic drive yesterday and today, car is still spotless.
