GU10 – Philips 6W Perfect Fit Dimmable Very Warm White (40°)
- 300 Lumens
- 2700 Kelvin
- 6W
These I’d say are spot on identical brightness with a 50W Halogen (so not as bright as the two above).  Colour is a little warmer than those above (you can notice the 100K difference) and again I’d say pretty much spot on with a Halogen.  They are the same size as the Halogens, so fit all my tighter light fittings fine.  Tested them dimming and they dim very well across a good range, but obviously unlike a Halogen that gets orange when you dim it these stay the same colour throughout.  Overall I’d say the lack of colour change when dimming is the only way you would tell that these are LED not Halogen!
Paid
£18.59 each from energybulbs.co.uk…  so not cheap
.  No other comments on the retailer, they haven’t been spamming me and I haven’t needed to contact them at all.
