the spindle did come out but now i have the whole plastic bit + center metal shell stuck inside my frame..
Drill it out?
jesus h christ.. im SO SAD right now ffs.. my wallet will hate me for ever.. i mean literally im like -250..
ill need a new frame or a magic way to remove the flippin bottom bracket or im stuffed.. and it looks like im stuffed!
i got the crankset off with a rubber mullet all cool and stuff.. but the other plastic cup broke of too!the spindle did come out but now i have the whole plastic bit + center metal shell stuck inside my frame..
AWESOME![]()
All I can think of is to make notches in the remaining plastic bits and use them to unscrew what remains. Don't know how that's happened.
Has anyone bought the yellow High5 box from Chain Reaction Cycles? How many Zero tabs come in the box? Trying to work out whether I'm better buying that or the red box from discount supplements.
tried that too.. everything broke in bits! not sure what the plastic is made of but it was CRACKING like a cheap chinese toy..![]()
It's not like people will be starring at your butt (that long anyway) to notice the bright raging orange thing you're sitting on![]()
I'm sure a small engineering firm would get that out for £50 or so, worth a call tomorrow.
Try carefully drilling lots of holes all the way around and then break it up into bits until its all out.
Maybe get a hacksaw blade and try to cut it in half (without cutting into the threads)?
Hills are awesome, you'll be grateful for them once you get your fitness up!
grudas, get it down to LMNH on old street, they'll sort you out
hopefully ill get some good news! as its been going to turd non stop the past two days!
