No, because I'm not. What would be the point? I'm not going to win and never was.
Uncore used to be twice what your memory multi is on x58,Idk if it still rings true for z87
It will do 4.4Ghz for pi 32m, and for games, but crashes in seconds in prime95, whatever the voltage. BCLK is quite limited (sub 105mhz really) on Haswell, but there is a gearing ratio you can set to 125 or 166mhz. I'll play with after I've finished messing around with my memory.
Most 4770k seem to be doing 4.4 to 4.6Ghz stable at 1.25v, with max stable speeds of 4.5 to 4.8Ghz. Mine is the worst performing one I've seen reported so far. Temperatures seem I line with what I'd expect for the voltage and clockspeed, but I just can't get stability at the high end
I think the 'uncore' might be the issue - it won't even post with that set to x40 (4Ghz), so it has to be left at stock.
Hmmmm, keep tinkering, some of the voltages probably need setting individually If on auto.
That is rather bizarre. Always adjust one thing at a time though, much easier to diagnose an issue then.
Nice time shadowwhat ram are you running?
Thanks. Nothing too special just some Sammy Greens 2x4GB.
Is 2200mhz the highest they go on haswell boxer? Tried 2400mhz with 11-11-11-21? Or 12-12-12-21?
Could be the bios, more stable releases will arrive over time. Is it the ram changes which are causing the problems?
1.7v is the most I dare run through my sticks.
