Pretty sure delvis has that self same look whenever something is explained to him.
am i right in thinking the average bar weight for a bench press bar is 20kg? if anyone uses a "The Gym" gym its the one they use.
Yep standard oly bar is 20kg
Tips for additional exercises to compliment strong lifts? I did 3x5 dead lifts and 2x5 RDLs today instead of the 1x5 dead lift which is suggested. Also did 3x5 on the leg press machine and 3x5 on the leg curl. Legs feel like death though so I may have overdone it. I forget there's squats every session :/.
You need to do variations on a curl to shock the muscle.
100% not srs. Follow the programme and read the manual again it has all you need. If you still have more in the tank following a session then just do what you feel like, as long as you have given the big three all you have.
Ha at first I was like![]()
But Dips, CGBP, DBSS, Pull ups, front squats, DB Rows are all good aux exercises.
If you can do additional front squats after doing 5x5 at your heaviest weight of back squats...son, I am impressed.![]()
Myfitnesspal
that bar is 20, but the standard bar believe me or not is over 10kg - due the fact that it has those "adapters" that allow you to use the same plates on standard bar and olly bar.. its quite a bit heavier than 10kg barbell so i guess its 15kg but i've never seen a standard bar weight that much!
