Sounds like a superexercise. Will try that pre and post workout
EDIT: So basically, a farmer's walk is picking heavy stuff up, and walking around while paying attention to your posture?
Any exercises or stretching techniques to drastically improve arm/wrist flexibility for power cleans? My wrists end up around 6 inches higher than they need to be regardless of how wide I grip the bar or how high I get my elbows.
My wrists just seem to hover around the same height regardless of whether my elbows are pointed forward or out. My hands also slant inwards so I have to try and rotate them outwards which is a ******* on the wrists![]()
Ends up around nose height. If you watch anyone press directly from a rack it's about the same height as when they unrack the bar.What are you doing with the bar (i.e. where is it)?
Elbow height isn't a problem although the higher they go the further past my head my hands end up.Wrists shouldn't really hurt unless you can't get your elbows high enough.
Yep, no problemCan you get your humerus parallel to the floor in the front rack position?
Post up a video with full sized plates
First time trying Deadlifting. Really need your help on this. Doesn't feel right at all. I feel like im too tall and im arching my back at the end to lay the weights down. I know its only 10kg weights so it will be lower to the floor, but still.
Im ashamed of my form. Help![]()
 It's kind of hard to give feedback on what is effectively you squatting down too far and standing up with next to no resistance.
