- 9 Apr 2012
For anybody interested in Plusnet, I have had a really good experience after being with them for almost 6 months now. Probably the best usage allowance + support one can get for the price!
What's modem/router that comes for free like ? Good enough or better to get another
.Its decent enough, its white in colour and is named technicolour.
I tried it the other day and its not bad but i bought myself an Asus RT 66U router which is absolutely immense if you can afford it...wireless was much better than the supplied router imho.
What about the wired speed? Only the missus uses wireless so ain't that bothered as she still gets over 20meg on it (55meg wired).
Def gonna get one after reading reviews of ityou tried using it to download .nzb files. It says it can be used as NAS through USB drive
Just buy a switch...
If you do the LAN2 port thing, I'm fairly sure you won't get access to the rest of your network. Say, 85% confidence.
But it sounds like you're wanting to entirely replace the router PlusNet provide?
Any router that supports PPPoE will do the job, though it's worth checking that it'll handle higher throughput first. Probably looking at £60+
Or you could spend like £6.50 and get a 10/100 ethernet switch and plug that into one of the ports on the existing router.
