- 10 May 2004
- Middlesex
I've had first hand experience of this, I've sparred with some people with BJJ experience, and in my case, strength and weight made a massive difference when I had literally no BJJ experience.
If someone can't move your arms or haven't got the strength to choke you out, their level of experience and technique are useless.
You know, their grip is easily broken so they can't hold a choke, they can't perform an arm bar because they couldn't break my grip, that sort of stuff.
I didn't win, but I didn't lose, because I didn't know how to do anything it was just me resisting until they got bored and gave up.
As a small (70kg) BJJ practitioner myself I also have first hand experience with this. Infact I beat a 110kg guy in a grappling competition a month or 2 back.
The guy you were rolling with probably just wasn't very good.
I'm not saying the small guy will always be able to submit the big guy, I mean if your arms are 3 times the size of my legs it's gonna be difficult but the small guy should be able to at least dominate.
When has ground and pound been associated BJJ it's more associated with a wrestling focused fighter.![]()
Ground and Pound is a relatively new concept. It's neither BJJ nor wrestling. Wrestling can negate BJJ somewhat as can ground and pound. But BJJ can also negate wrestling and ground and pound itself. Again, it depends on the skill level. However, the Gracies were using ground and pound before MMA even existed. The best MMA fighters use all 3.
