Very nice too, will you be using 1600p full time now.
Yep, getting much better usage per card in bf3. With the i5 they would max at 80%. Seeing usage into the high 90's now and the game feels a lot smoother.I will leave your score with the 3570k in the table as well.
Have you noticed any difference using the hyperthreading on the i7 ?
Very nice too, will you be using 1600p full time now.![]()
That's the plan
If you give your cards a run out on Unigine Valley @1600p, you should get a nice surprise.![]()
i7 3770k @ 4.7GHz
GTX 680 @ 1255/3525MHz
Hi guys,
Been having problems with getting abysmally low FPS in the Witcher 2 on my newly built rig /w i5 4670k and Asus DCUII gtx 770 all at stock.
Someone in my thread (http://forums.overclockers.co.uk/showthread.php?p=24579855#post24579855) suggested running the heaven benchmark at your settings and seeing how I did.
I forgot to screencap my results, but I got a score of 961.
Is that roughly where I should be with my setup?
If anyone fancies helping me out please do head on over to my thread!![]()
gigabyte gtx760 1190/1255 mem 1850
fx6300@4ghz
I did try to but it just did my desktop. So I saved it. How do I do the in bench screen shot? Sorry for the noob question![]()
My highest reliable score (1014) on:
i7-4770K @ 4.6GHz
GTX 770 @ 1280/3505
It is good to have another GTX 770 on the scoreboards.![]()
Mine after a little clock...
Score 1226
GPU GTX 570 (2560mb) x2
CPU i7 930 @ 4.03GHz
Graphics: 812MHz
Memory: 2000MHz
Processor: 1624MHz
