Well I did what weight I could
There's no way you can only DL 10KG more than you can curl unless your back is made of sponge.
Lift more next time, particularly on the rows and deadlifts. I might forgive caution on the deadlifts, but 12.5kg single arm rows are pointless.
If that's genuinely how strong you are then you have my fullest support. However, if you're barbell curling 20kg 3x8 then that isn't how strong you are.
To break that down approximately:
That's 10kg per bicep. To only be rowing 12.5kg means that all of the rowing musculature of your back can only handle an extra 2.5kg, which is clearly nonsense.
Not being rude Grudas but if you read my posts then you would see I already accept that I can lift more I was just wary of doing so. I don't think I can do 70kg but I've never tried so we will have to see and also quite frankly everyone is different so because you started at X doesn't mean I can do the same.
Cheers ice, yeh I have checked them out and also checked it when I was at the gym to ensure I was doing it right.
Hnnnnng 18.5T shifted.
RIP
Will check those out now. Cheers ice.Lunges, deficit bulgarian split squats with DBs
Do enough of those and you'll be fine.
