My drunken eye thought there was a bottle cage under the down-tube, but it's the toe clip on the other pedal![]()
[DOD]Asprilla;24676263 said:Ohhhh, I found a picture.
Ohhhh, i wsh you hadn't
Please get your mate to buy that frame and treat it right.
Hi guys i've ordered a set of chinese carbon wheels and they come with a 11 speed Shimano compatible freehub body, will my 10 speed cassette just slot right or do i need some kinda spacer?
I'm a medium in Rapha gear, and a Large or sometimes XL in Castelli.
Should probably go for a quick spin whilst there's still some blue sky, I guess.
Quick cup of strong black MTFU sorted me out though. Did a relatively flat 23mi and tried to make it count as weather is looking dire for the week ahead
You will need the 11 speed spacer from the wheels, kinda like the mavic ones, and also your 10 speed spacer than comes with the cassette if it's a shimano 105 and above.
Tiagra cassettes don't use a 10 speed spacer, nor do Sram 10 speed.
Quite like it now I'm used to it and the wife approves so all good!Hmm it does not say in the ebay description that it comes with any sort of spacer and i don't know what cassette is on my current wheels as it does not say on the specs and i can't have a look right now as they are in a shop but the derrailleur is Ultegra if that makes a difference.
So let me get this straight, there should be a 11 speed spacer with the wheels and there might be one on my cassette. If there isn't one with my cassette does that mean i don't need a 10 speed one for that cassette?
Managed to confuse me, I have the merino under layer in L which IMO is too baggy.
Then I have the pro base layer in L which fits perfectly.
I was going to order a lightweight jersey in L my chest size is 100cm, and bibs I wasn't sure on M or L.
I'm about a 33" waist and a 34 leg.
My L castelli top fits great, the L castelli bibs are maybe a tiny bit on the small side....
Surely that's the sort of thing you find out before you click the 'buy' button?![]()
