My drunken eye thought there was a bottle cage under the down-tube, but it's the toe clip on the other pedal![]()
[DOD]Asprilla;24676263 said:Ohhhh, I found a picture.
Ohhhh, i wsh you hadn't
Please get your mate to buy that frame and treat it right.
Hi guys i've ordered a set of chinese carbon wheels and they come with a 11 speed Shimano compatible freehub body, will my 10 speed cassette just slot right or do i need some kinda spacer?
I'm a medium in Rapha gear, and a Large or sometimes XL in Castelli.
Should probably go for a quick spin whilst there's still some blue sky, I guess.
You will need the 11 speed spacer from the wheels, kinda like the mavic ones, and also your 10 speed spacer than comes with the cassette if it's a shimano 105 and above.
Tiagra cassettes don't use a 10 speed spacer, nor do Sram 10 speed.
Hmm it does not say in the ebay description that it comes with any sort of spacer and i don't know what cassette is on my current wheels as it does not say on the specs and i can't have a look right now as they are in a shop but the derrailleur is Ultegra if that makes a difference.
So let me get this straight, there should be a 11 speed spacer with the wheels and there might be one on my cassette. If there isn't one with my cassette does that mean i don't need a 10 speed one for that cassette?
Managed to confuse me, I have the merino under layer in L which IMO is too baggy.
Then I have the pro base layer in L which fits perfectly.
I was going to order a lightweight jersey in L my chest size is 100cm, and bibs I wasn't sure on M or L.
I'm about a 33" waist and a 34 leg.
My L castelli top fits great, the L castelli bibs are maybe a tiny bit on the small side....
Surely that's the sort of thing you find out before you click the 'buy' button?![]()
