Road Cycling Essentials
Status
Not open for further replies.
Hi guys i've ordered a set of chinese carbon wheels and they come with a 11 speed Shimano compatible freehub body, will my 10 speed cassette just slot right or do i need some kinda spacer?
You will need the 11 speed spacer from the wheels, kinda like the mavic ones, and also your 10 speed spacer than comes with the cassette if it's a shimano 105 and above.
Tiagra cassettes don't use a 10 speed spacer, nor do Sram 10 speed.
I'm a medium in Rapha gear, and a Large or sometimes XL in Castelli.
Managed to confuse me, I have the merino under layer in L which IMO is too baggy.
Then I have the pro base layer in L which fits perfectly.
I was going to order a lightweight jersey in L my chest size is 100cm, and bibs I wasn't sure on M or L.
I'm about a 33" waist and a 34 leg.
My L castelli top fits great, the L castelli bibs are maybe a tiny bit on the small side....
Should probably go for a quick spin whilst there's still some blue sky, I guess.
It poured down here overnight. Our gang were due to go out this morning, so the roads will have been nice and wet for them... Need to check what the weather is doing this week so I can figure out what I'm doing!
so what's wrong with that picture then?
all I can see is the front mudguard is fitted wrongly or something about it
or they've fitted flat bars to it when it had drops ? so that be wrong! lol
Hmm it does not say in the ebay description that it comes with any sort of spacer and i don't know what cassette is on my current wheels as it does not say on the specs and i can't have a look right now as they are in a shop but the derrailleur is Ultegra if that makes a difference.
So let me get this straight, there should be a 11 speed spacer with the wheels and there might be one on my cassette. If there isn't one with my cassette does that mean i don't need a 10 speed one for that cassette?
Did I mention I got the razor out in France? I'm not going to justify it with spurious sporting reasons, it was a pure vanity thing. :p Quite like it now I'm used to it and the wife approves so all good!
Surely that's the sort of thing you find out before you click the 'buy' button? :rolleyes:
That's because you should size your bibs on height as much as anything. I take a medium or large in bibs but a small in jerseys. Small bibs would look like hotpants!
Status
