I would if I had any money, but also the trouble is the DLC is more than the Ultimate Edition!
I'll see what happens
Thinking of getting Ultimate Edition does it come with all the DLC available for new vegas?
If I have the standard new Vegas, can I buy the ultimate still?
I'm not helping anyone who wiped out the brotherhood of steel
You only ever had one save, you never made a manual save?
Very risky when it comes to Fallout 3 / New Vegas![]()
My auto save wont loadjust stays on loading screen for ever. Is that it am I done? Not sure I can be bothered starting yet again, was enjoying it as well
Whats the quest lines a new player should start off on ?
What I usually do when a save fails is start a new game, then manually load that save whilst im in a 'different' game. Usually works.
I would be worried in your case that it might save over the autosave, since I've always kept a minimum of 3 rotating saves I've never had that issue - have you got any other saves you could load first, then load your auto from within that game? Good luck fella![]()
