This new driver is solid. It allows me to add another 25mhz on the core clock of my gpu without crashing.![]()
I have a 4770k @4.6 and crossfire 7970s @ 1000/1375 and my score is-
http://www.3dmark.com/3dm/1026378?
From what I understand its supposed to be better than this?
I have seen single 780s getting 18k![]()
13.8 Metro LL Wow! Super smooth full max settings 1080p.
Still having issues with BF3 thoughthe frame rate just dont feel smooth at all.
Went from a i5 2500k to a i7 2600k and not much a change. the CPU usage is much lower on the i7 but I only seeing max GPU usage of 70%
But everything else is running great so far, do I just call it BF3 is a very badly optimized game?
Shankly it's the Mesh detail that's the FPS killer in BF3.
[email protected] 7950 CrossFire@1000/1375:
11611 v's your 11827
http://www.3dmark.com/3dm/1031019?
It is if you ramp your clocks up:
[email protected] 7950 CrossFire@1230/1500:
13097
http://www.3dmark.com/fs/495750
You need to stop that crack habit.![]()
I know mate it's eating into the PC budget! rofl
I'm using firestrike and by mistake I was comparing it against a dif one.![]()
Are you getting good results now with games in crossfire?
Crysis 3 runs like butter now mate as does metro even to the point where not only do they feel smoother I am sure they have gained fps as well but I never knew what numbers I was getting. I picked up Resi 6 for cheap and found I have to disable frame pacing in that or it stutters like hell (irony) but other than that I havnt tried too much else.
I wish i could say the same. Tried Crysis 3 using crossfired 7950s. Ran like a snail, first level was extremely laggy with high input lag as well. Seems to run fine on a single GPU though.
Think im going to put my entire crossfire on the shelve for now and wait til i have the money for a 4830k or something along those lines..
i'm on a single 7970 13.5 cats here, any point updating??
