I pre-ordered a H80 yesterday but could I cancel and get a H100? I have a Corsair 300R case. Officially it doesn't fit but I've seen people getting it to fit snug.
Surely these actually have a 6 year warranty, due to the retailer being liable for 6 years under the sale of goods act? If the item breaks in the first 6 months, it's up to the retailer to prove the item wasn't faulty at the time of purchase. Therefore, these have at least 6 months. It makes no difference that these are refurbished. One enters into a contract when you buy something, whether new or used.
Check here http://www.overclock.net/t/1144409/...compatibility-thread-page-1-for-full-listingsOkay I will do if I can be absolutely sure a H100 will fit my 300R case. Does anyone know for sure if it will? I've a Gigabyte Z77 D3H mobo.
What speed setting on the pump do you guys have it set on?? got mine on 3 at the moment
Quick test I did. 3 was a bit noisey for me but 2 is quiet and not far off temp wise.
AMD FX 8350 @ 4.0ghz
H100 performance 3 lights
stock fans
Idle - 12c
Prime 95 20min - 31c Much louder.
Quiet 1 light
stock fans
Idle -12c
Prime 95 20min - 39c
Balanced 2 lights
stock fans
balanced 2 light
Idle - 12c
Prime 95 20min - 34c
3c wasn't worth the noise to me.
Right might try it on 2 then
Running an i7 950 and its idling at 37C on one core and a low of 32C on another.
Maxing it out on Prime climes to around 60C
Are H100 Still in stock or are people still waiting on them? By that im asking.. buy tmoz will i get it tuesday?
Yeah as you surely saw in my post I got the Quiet and performance modes mixed up.
Is definitely worth a shot on the balanced mode, so much quieter if nothing else.
so not sure whats going in there. sounds much better now.
