** CORSAIR LIQUID COOLING SOLUTIONS - CRAZIEST DEAL OF 2013 **
Did every one who's has arrived receive it via standard first class post?
Mine on the invoice said it was suppose to arrive Saturday but still has not turned up today.
You know what you need to do then. ;)
*hint* Customer Service forum with your order number.
Just a token to say thank you for ordering. :)
As for the ETA on the H80 we will know more on Wednesday when Rich is back in. :)
Could we please have some clarification on warranty as a few of us have had the H100 turn up with a one year warranty sticker on the box. :)
I wouldnt personally worry about the odd few but say more than 1/4 of the one side would have me thinking about it. Depends if its going to restrict air flow through the rad.
Think the post man ate mine :(
On a sidenote, got home this evening and set it up for leak testing. Seems pretty darn quiet tbh. Pump is almost silent, love how it powers the fans to full speed on startup to ensure the liquid is cool enough for load. Great piece of kit for £40!
As for the ETA on the H80 we will know more on Wednesday when Rich is back in. :)[/QUOTE]
I bet Rich is sick of all the H80 buyers moaning LOL that he is at this moment wizzing his way over the sea in a Sea King helicopter to meet the ship and get our coolers...LMAO.
Question for those of you who are using the stock fans that come with this. How long is the cable on them. Im having to mount the rad inside the case and the fans outside on the top of the H100. But it means routing the cables into the case, probably via the first PCI blanking slot ( above my GFX card ) Will the cables be long enough or will I need an extension?
EDIT : This should do the trick shouldn't it?
http://www.overclockers.co.uk/showproduct.php?prodid=CB-011-CT
The length of the cable for each fan is about 3 sides of the 120 fan that comes with the unit
That cable will work fine if you need it
Yep ill deffo need those extensions. They are 3 pin fans aren't they?
Yes.
Just finished fitting my H100 after running it for a couple of hours on the desk.
There's three/four bent fins on one side, but nothing that would affect the airflow.
Idle temps are 29C, load is about 45C on stock clocks.
The fans provided are stupidly loud, even the corsair SP120 high performance running at 2350RPM is quieter then the one provided.
Im ditching the H60 now and going for a dark rock pro 2 which i got for £40
My idle temp is 45c and under load depending on game it shoots up to 70-80c which is pretty poor
If anyone is bothered about having bent fins just straighten them up with a non metal device, you can get a plastic fork break off the large outside prongs them middle ones leave your self with one thin prong and use it to straighten them up. I straighten radiator fins in the garage with a large plastic comb and never punctured a fluid tube yet, they are stronger than you think..
