- 14 Dec 2011
h100 arrived installed into my prodigy build, just need to sort the fans out since they do make quite a racket.
The pre-applied stuff is quite good by all accounts MikeTheNative. I've left it on mine, seems to be idling around 15 degrees.
Did every one who's has arrived receive it via standard first class post?
Mine on the invoice said it was suppose to arrive Saturday but still has not turned up today.
Just a token to say thank you for ordering.
As for the ETA on the H80 we will know more on Wednesday when Rich is back in.![]()
Could we please have some clarification on warranty as a few of us have had the H100 turn up with a one year warranty sticker on the box.![]()
[/QUOTE]Question for those of you who are using the stock fans that come with this. How long is the cable on them. Im having to mount the rad inside the case and the fans outside on the top of the H100. But it means routing the cables into the case, probably via the first PCI blanking slot ( above my GFX card ) Will the cables be long enough or will I need an extension?
EDIT : This should do the trick shouldn't it?
http://www.overclockers.co.uk/showproduct.php?prodid=CB-011-CT
The length of the cable for each fan is about 3 sides of the 120 fan that comes with the unit
That cable will work fine if you need it
Yep ill deffo need those extensions. They are 3 pin fans aren't they?
