When exactly are these meant to be dropping in price? Seems they're still the same price at most places.
Will you and Catanonia be posting scores on the Unigine Heaven 4 thread, Diagro is the only one with a HD 7990 score on there.![]()
Is it worth me going from a single 680 to a 7990? Was going to go sli, but I'm undecided whether that's the best route to go down considering the vram limit.
Well you would get over twice the performance you're currently getting.
Ok...so I'm benching at Stock tonight vs an OC'd SLi GTX 760 will post some results up...first some pics in the case![]()
How loud are the fans as some say they are loud ?
Did you get the 7990 in that recent £530 deal?
Good stuff jrodga. Make sure you use the 13.8 beta drivers and disable ULPS with msi afterburner or Trixx.
will need to try this.Haven't benched with it off yetwill need to try this.
Make sure you do, you'll gain extra performance.
Giving a few a go...
