$599=£373.93+****VAT=£74.79=£448.72=over priced
Not over-priced if its beating a Titan. Its a superb deal.
$599=£373.93 now thats good deal
Not £448.72
Ugh, wccf still pushing the incorrect info about die size...
If the rest is true, quite impressive on launch drivers. Also note how Hawaii outpaces Titan with AA every time.
512bit bus.
Its why the 7950/70 outshine a 670/680/760/770 at high resolution/high AA settings.
EDIT
This card is going to overclock like a champ. The memory at only 1250 is going to have massive overclock potential.
There is something rather odd about vram clocked as low as 1250 on a high end GPU, even the Titan with its 6gb comes in @1502.
Kinda makes sense with a 512bit bus though. It doesn't need to be clocked as high. 512bit at 1250=288GB - 7970ghz 384 bit at 1500=299GB. The 7970 was definitely not short of memory bandwidth. Looks like it will be even less of a problem here. Hynix memory. Always good for 1700-1900mhz with golden chips reaching 1900-2000.
You forgetting one thing though. If those result for the top card Hawaii XT beating Titan is indeed true, it would mean AMD's 2nd card down the Hawaii Pro would be beating the GTX780 at sub £400 price range.$599=£373.93+****VAT=£74.79=£448.72=over priced
I think there's always a misconception for many people thinking about memory bandwidth in the sense like vram which can run out, when they are actually more like core clock the higher the better; the core clock is for pushing the raw frame rate up, whereas the memory bandwidth speed is for reduce the amount of frame rate drop when applying graphic settings that are memory intensive such as MSAA and SSAA etc- basically the higher the memory bandwidth, the lesser frame rate drop when using AA etc. It is a case of the higher the better (that actually make a difference to performance...unlike more vram), rather than the case of having "enough" or not.Kinda makes sense with a 512bit bus though. It doesn't need to be clocked as high. 512bit at 1250=288GB - 7970ghz 384 bit at 1500=299GB. The 7970 was definitely not short of memory bandwidth. Looks like it will be even less of a problem here. Hynix memory, always good for 1700-1900mhz with golden chips reaching 1900-2000.
Beats Titan by a few percent??![]()
We'll see mat. Don't get too excited just yet. Want to see benches on these new cards. I'll chuckle if their not much faster then what's out now.
Looking forward to the reviews, but the only thing I am really interested in is the overclocking headroom.
It is easy these days to produce a GTX 780 that off the shelf is faster than a Titan but when it comes to overclocking both, the result is reversed with the Titan coming out on top.
If the R9 290X has decent overclocking headroom and can produce the numbers then there maybe some headed my way.
I have one of these on order at the moment
http://www.overclockers.co.uk/showproduct.php?prodid=MB-587-AS&groupid=701&catid=5&subcat=2174
So it will be interesting to see what ends up in it.![]()
Right im throwing my hat into the ring. Titan beating performance at $550+. You heard it here first folks. I may or may not have heard it from someone else.![]()
