OK, I've just installed 2 of these cards.
Heaven score is lower than I'd like, but I'm wondering if you guys can help me with this problem and another I've been having...
First off, I'm using Precision X (as it was already installed).
When I've got no apps open the 2nd card seems to power down and doesn't show any voltage or gpu speed. However as soon as I open any app the second card kicks in and runs flat out 99% usage. It's really annoying, any way around this?
Secondly, when running Heaven the first card hovers around 99% usage but the second card keeps dropping to 64% usage and then spikes up to 99% and then drops back down. Any idea how to fix this, the power target thing is already at +20%.
Also, is it normal that Heaven only shows the stats for 1 card with Crossfire? (it showed 2 with SLI).
Thanks.
1. Real men don't use precision X.
2. Disable ULPS via afterburner.
3. Flash the first non boost bios from the OP.
4. Use the bios flashing guide LT posted in the OP or in the second post in this thread.
Report back if needed.
