Haha, minions are ace. My lil girl wants some, I bought her the teddy versions, she wants them to be real![]()
Well, tell her that's what imagination is for. We seem to be applying enough of it to the likely performance of forthcoming GPUs
Boom, i know you love Nvidia, but, come on, He has told some pretty good Lies before. Jokester made reference to one whopper he told. The two examples you gave for power use are bad examples. The 5800k to 6800k are APU's, the powersaving was made by managing the way the cpu and gpu work together better. For your other example, the 4870 and 4890, you do realise that the 4890 was a different chip entirely? RV770 to RV790. Even if they were the same chip, it still wouldn't support your argument, because while the 4890 used less power at idle, it did use way more under load.
We know the 780Ti is a GK110 chip. We know the GK110 is very efficient as it was designed to work in supercomputers with strict power demands. You think they are somehow magically create more performance for less power?
It will definitely be cooler and quieter than the 290x but will it be cooler and quieter than a stock 780?
But you would have to be living in dreamland to think it is going to use less power than the titan.
Not really the 5800K > 6800K was an example everyone can follow, same chip, same die node, tweaked design for less power consumption and better overclocking. Same logic applies to GPU's. The latest GK110 revision, could have better power consumption to performance ratio.
Also the 4890 was exactly a tweaked 4870, they added a de-coupling ring, an additional 3million more transistors than 4870. Included improvements / tweaks made, but there is no logic design changes. Same architecture, same die node, resulted in better performance at stock and much better overclocking.
Likewise the GTX 780ti has more shaders, along with tweaked design. We just have to wait for reviews now to see how it compares.
Which leads me to another question, you obviously believe all the leaked benchmarks that you have been posting, so how can believe them and not the power consumption figures with said benchmarks?
Not sure why people are having a go at Boom. I say lay off him and his analogy does work.
Before we brought you Nvidia 780 Ti’s benchmarks, now we bring you its overclocked benches, only a few are available but believe me when i say, they do not disappoint. The source is again the credible Chiphell forums.
Overclocked 780 Ti Significantly Better than the R9 290X
Firs things first, the comparison is between an overclocked GTX 780 Ti with its stock self and the R9 290X. We would like to point out that unlike the R9 290X the 780 Ti’s cooler is quite sufficient for OC whereas the R9 290X is not. It might be more fair to wait for the Custom models of the R9 290X to show up before pitching in. Still the results speak for themselves.
Read more: http://wccftech.com/overclocked-780...massive-overclocking-potential/#ixzz2jfR0616H
Anyone taking the plunge on 780 Ti then?![]()
6192 is the same as what WhyScotty scored and this 780Ti is reading over 1320Mhz. I call fake on the slides, purely on knowing what is what with Titans. I think that is a Titan mincing about as a 780Ti.
How much is this looking to be in UK? £550 roughly?
