i dont like vertically mounted mobos though lol
sagging gpus and all that...
Blocks of wood cut to size work great
but that makes it look ugly through the window =x
YOUR BASKET
1 x Lian Li PC-V358B Micro-ATX Cube - Black £129.95
Total : £129.95 (includes shipping : FREE).
this case takes my fancy at the moment, definite support for 240mm thin rad, if the front can fit another 240mm rad without much modding, i think this'll be my next case
damn. that's some pretty good clocks. i hope mine's like that lol
and that's your heating for the winter...
Anyone?? You guys using Asus GPU Tweak instead of MSI Afterburner?
Anyone else having issues with BF4? Mine seems to be crashing with out of memory errors after about 5 minutes. When I check afterburner it's showing gpu memory usage @ 3500mb.
This is at 1080p Ultra settings, that can't be right...is there a memory leak?
Have u got the latest catalyst drivers ?
Are u overclocked, if so reduce oc on memory
nah AB is the best.
For benching I use 1.3v under water, normally for games I run stock, but I do have 2 of them under water.
How did you get your mem to clock past 1575? That's the highest the slider would go for me in AB. + no mem voltage![]()
Hello
We have a long threat about this issue in Spain
http://foro.noticias3d.com/vbulletin/showthread.php?t=417100
Please use Google translation
http://translate.google.es/translat...icias3d.com/vbulletin/showthread.php?t=417100
Look at the graphs.
Our preliminary conclusions is that the power fase are insufficient so the card has to regulate it self. In w8 it does OK but in w7 doesn't. So if your voltage is lower than 11.5 V de load will drop in w7 from 98 to 60 % jumping all the time and in w8 to a constant 92%.
The only solution to get the best of 7990 is a gold power supply higher than 800w with w8 and power limit +20%.
Do you have the same experience or the 7990 series that have been sold in Spain are wrong?
Thanks
Seems i cant take the core past 1100 without it locking up in 3dmark...Managed to take the memory to 1650 though on default voltage and could probably take it further. Seems like a good overclock overall.
