Caporegime
- 18 Sep 2009
- Dormanstown.
There's an MSI command for 0.1v
Just got my card!! very happy. Yeah its a little loud but not as bad as people have been making out. It is less so than the hd 7990.
Hows the performance difference in comparison to the 7990?
I said I wouldn't but new shiny and all that, had thought of going green but idk if I can stomach the £80+ price difference and I have a spare AC Extreme.![]()
I know that, I'm asking as I'm using 7950 CrossFire=7990, wondering if the performance hit is a lot.
Just to warn people I have had a weekend of testing all my new parts because the screen would just go blank no bluescreen or crash just blank in windows and if I start something like minecraft it would do the same sometimes after 15-20mins other time after getting in to windows 5-10seconds
Anyhow it was the graphics card drivers I used the new beta ones from amd so Before doing a rma I thought to my self install the drivers off the disc and bing go no crash for 45mins so far and even ran 3DMark without a problem and even minecraft didn't crash it.
So if your having crashing problems just the driver off ur disc till amd sort out there stuff
All I have to do is reinstall 8.1 now as I install 7 just to rules that out
Ps my model is the gigabyte 290
blank screen seems to be a common issue for many.
any driver should work if they designad for the card.
I would rma as I have zero tolerance for such.
Using old driver for now and it runs fine so far
Also the new driver does say Beta so not to worryed about that just wanted people to know there still very buggy atm
Okay so went back to drivers off the disk and I get black screen and PC either locks on it or shuts down. PSU? or dodgy card?
Gutted as I've spent weeks waiting to buy a new card to replace my broken SLI set up.
List of things to do,
flash latest bios MB.
check psu and even try different cables.
try it in another computer if possible.
try a different pci-e slot.
change pci-e 2.0 to 3.0 if doable etc..
