I wonder if i should just keep a rear exhaust and try making my four side exhaust fans intakes? Hmmm.
The top fans are connected to my H100i. If i use that as exhaust my cpu temps will likely plummet. I have that as intake for lower cpu temps and the H100i doesn't kick out too much heat, just a little bit of warm air.
Could be the PSU, mine was a HX650 not 620! It's only Bronze efficiency but it was a Corsair so very good quality PSU.
I imagine my new platinum EVGA should have no issues, would you mind sharing the power hack (is it the regedit one)? I was looking at the bios editor as per the other thread as it's a lot easier but wanted to check it actually worked for 7990's before tinkering.
A good 850w depending on other components I would say. Corsair AX860 or go for the EVGA 1000w Plat (fully modular) like I did for the same price
http://www.techpowerup.com/reviews/EVGA/SuperNOVA_P2_1000/11.html
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=361
You have a blower though Rossi don't you? Blowers have their drawbacks but they get most of that heat out the case asap.
You really think trifire would run on a 860w?
I have the AX860 but didnt think that would be enough to add a 7970.
Hmm on the overclocking for afterburner do you enable with or without powerplay support? My voltage option still seems locked.
Neither leave that disabled and instead tick extend official overclocking limits, and tick unlock voltage.
Have to agree I think your temps look about right! Will try and get a quick run in before I go out tonight but if I can't will definitely tomorrow morning.
I am tempted to strip down the cooler and apply some gelid extreme but I've heard the 7990 uses some phase change thermal paste and is not really meant for disassembly unless replacing the entire unit. (Still I'm tempted)
They use some kind of paste that hardens after it is applied, had a hell of a time scraping all that off to get my waterblock on![]()
Yep heard that nothing a credit card, toothpick and artic cleaning fluids can't handle...I hope
Were there any warranty void stickers etc?
The slight coil whine the card had when i got it has reduced a fair bit already. I can see it disappearing completely over time.
How's the 7990 going, pleased with it?
