http://forums.guru3d.com/showthread.php?t=383541
new MSI AB beta 17 is out !!!
Voltage control here we come... But at work atm
May I please ask, has anyone RMA'ed their 290x due to the black screen issue, if so, what happened?
I'm still conflicted about what to do.
Does it do this in multiple games, or just one or two, if so which one?
All games. It's the widespread issue discussed in these threads:
http://forums.guru3d.com/showthread.php?p=4700994#post4700994
http://hardforum.com/showthread.php?t=1789166&page=7
http://www.overclock.net/t/1441349/290-290x-black-screen-poll
http://battlelog.battlefield.com/bf4/forum/threadview/2955065218069487298/1/
http://beyond3d.com/showthread.php?t=64565
http://www.simology.co/forums/gaming-platform-pc/3302-r9-290x-display-black-screen?limitstart=0
http://www.xtremesystems.org/forums/showthread.php?287807-AMD-290x-black-screen-in-BF4-....
I think this one says it all.
Use this to see what memory you have, run as Admin.
http://www40.zippyshare.com/v/47188236/file.html
Do you have the 13.9 WHQL drivers? is so try them.I have elpida memory, but does this still point to a hardware defect, or something else? That's the question.
Also please send AMD a bug report so they know about this.
http://www.amdsurveys.com/se.ashx?s=5A1E27D25AD12B60
If the 13.9 driver doesn't fix it, i would send it back.
You fixed you black screen by making sure the 8-pin and 6-pin are on different rails, or did i read that incorrectly?
I think someone here http://forums.guru3d.com/showthread.php?p=4700937#post4700937
...claims to have fixed it by setting the fan speed to 100%, even though this doesn't change his temps.
I give up.
The fact that everyone is now getting the BF4 key = lol, it's like the universe has designed this launch to progressively enrage me on points of principle.
Na black screen again in BF4 with system lock up, was worth a shotwill play around with the set up more.
P.S. CEUOTC you might want to give that fan fix a try. Can't hurt.
Well set the fan to upto 100% and still get the Black screen, this time in WoT![]()
How did you fix it, out of interest? In CCC?
I only ask because the poster who claims this fixed his issue stipulated CCC - and as the RPM of the fan and the temps do not change, as we all know this not a temp issue, it might be relevant that the change is made in CCC and not something else. God knows. if this is the fix it's an insane bug.
I've seen two people who fitted aftermarket coolers to their 290x's and now having the problem. Fell so bad for them if it does turn out to be hardware![]()
