Which coin?
Lite coin, I wish it was bit coin at the prices. Lite coins slowly rising so one can dream.
Which coin?
I assume having a 7970 in the top slot and 7990 in the bottom isn't an issue? The reason I ask is my x-fire isn't working/the option isn't there. I updated drivers too.
Oh and I have checked the obvious things, crossfire bridge connected, pushed in mobo fully, power cables in, restarted once after driver update.
Been playing about with 24/7 gaming overclocks in preparation for my 7990 benchmarking thread. Seems long term stable the max my card will do is 1140-50/16-30-50. To run that id need 1.3volts which is more than im willing to put through it. I can bench a bit higher than this but its not long term stable. My long term max stable gaming overclock will be 1125/1625 @1.260v. This means i have to kick the fan up with a more aggressive profile though. Fan profile is up at 80%-ish and was keeping BF4 with vsync off at 85c-ish. When using stock (1000/1500) or a smaller overclock of 1100/1600 i can probably get away with using auto fan and keep the card nice and quiet.
Sounds quite close to mine. Im running 1100/1630 24/7 which is stable at 1230 volts. I managed to take it up to 1150 on the core but it needs about 1260+ to be stable at that and it starts running pretty hot once you get that high so just leaving it at 1100/1630 which flys through any games.
Received my 7990 all looking good. Just noticed it hasn't got a gold or silver ticket? I was under the impression they all came with one? Can anyone confirm what the deal is with these? Cheers.
Got mine today - first impression, oh so quiet!!! Thank goodness the cooler is improved.
Any coil whine?
I still sort of wish I had a 7990![]()
It gets emailed to you (says on your order).
Oh really, never even checked that! Yes, it is very quiet I must admit. Struggling to get MSI Afterburner to show do the onscreen FPS, GPU Usage etc.
Teppic, no coil whine what so ever!
The 7990 HAS to be the top/main card. I am running a 7990 and 7970 and it won't work unless the 7990 is the main card.
