Anyone know why my fans are nearly 1000rpm (one at 60% the other near 80%) in difference, the core and vrm temps are the same on both gpus, in fact the lower one is hotter lol?
If your on stock clocks try undervolting a little to help temps.
There are only three fans so they don't operate at different speeds. Ignore the reading, its wrong.
Being new to Crossfire is there anything I should read into for getting the most out of each game? Awkward googling for stuff as it brings up so much old info for previous drivers.
I'm seeing good FPS in dayz but it feels like it's really stuttering, almost like its worse frames than it actually is (although this could be due to the AMD Patch i'm using to get 120hz on my monitor) and also in CSGO i'm not seeing any real improvement. Both CPU & GPU seems to be under utilised, could be the beta drivers I guess...
I've had a quick look at RadeonPro but soon as I tweaked CSGO it forced it into insecure mode which instantly put me off, can't have a VAC Ban on my 4 digit![]()
AMD patch to get 120hz??
What is your CPU usage at when your GPU's are under low usage..
Yeah I don't think source engine uses two GPUs and dayZ is completely cpu bound.
Everything in LtMatt's sig will give you what you need.
gpu 1's fans are the 2 fans closest to the pci bracket
gpu 2's fan is directly below the power connectors
you can control either independently of each other
In the name of all thats holy Matt remove that red font it burns my eyes![]()
2 x 7990's arrived and working a treat, thanks to Mr Gibbo and his black friday nuttyness![]()
I did indeed Matt but change is allways good. Had saved me pennies towards these classified 780ti's whenever they land but the opportunity to be able to claw back costs seemed an opportunity I could not pass up![]()
