- 15 Mar 2010
- Bucks
^ Not sure if serious.
please show me one bit of evidence that proves that its a fact and not just some jumped up gym ethics....
Chalk, Straps, Gloves there all built to maintain grip.
Chalk, Straps, Gloves there all built to maintain grip. Chalks still the best I agree, but im not going to go about claiming gloves are the devil in gyms.
Firstly, what on Earth is a bicep pull down?
Secondly, I'd go against the grain here and say I would happily use straps on BORs. There's no point letting the weak link in your body (in this case your forearms) hinder your other muscles (in this case lats and biceps) from getting the benefit of the exercise.
Your lats may develop strength a lot faster than your forearms, and there is absolutely no need to hinder that development by not strapping up.
FWIW, I have used straps for BORs, but I don't currently. My grip is fine and challenged enough with deadlifts and other back work, including bicep exercises (anyone else get sick forearm pump from barbell curls?). What I would recommend is getting some liquid chalk, it will improve your grip massively without the need of resorting to straps.
I wish UE was still here as he would answer that very well. He uses straps for BORs and from what I remember it helps activate the lats more and less to do with your grip at all. Though I can't remember why...
Even chalking up for pushes makes a big difference in my experience, but I do have 5 year old girl hands.
Meh, using straps on BORs makes the lift target your lats more if you pull correctly. So basically what I said, using straps takes grip out of the equation.
Careful, can't be spouting that sort of thing around here man
Using straps doesn't magically target your lats more though, that's the pointIt's the fact your lats aren't engaging as much to compensate for the lack of grip; they're retarding their power because they don't think your body can move the weight. So yes, it takes grip out of the equation (to a degree), but that isn't what he was asking as I'm pretty sure he understood that part of it
He was asking what the connection was between using straps and getting better back activation.
And I'd completely agree with what Chris said there as well; improved chalk on bench results in a steadier bar which also gives more confidence. It's not a straight forward case of "chalk increases lifts", there's sensible reasoning behind it.
Double Overhand > Hook Grip > Chalked > Strapped.
I read an article/watched a video by Christian Thibadeau many moons ago, obviously each to our own, but he was strapped up for snatches to save stressing his CNS unnecessarily.
That's not to say he negates grip training, not at all but is conscious that like training any other muscle it does effect the CNS, squeezing the living **** out of a bar for what totals a couple of minutes at a time.
Can confirm, deadlifting with straps does change the way the lift feels entirely. If you've ever got to the point on a RAW deadlift when grip starts to go and your entire body freezes and goes full derp 'nope, not moving any further'.
I did loose my grip a few weeks back on a 160KG when I wasn't expecting it, needless to say my arms flung up past my head and knocked me off balance
I'll avoid straps for as long as possible and I do feel like a pratt using them. DOH 180KG now so grip is improving, just such a slow process.
I know that feel.. lost it at 160kg too, I only started using straps a week ago and only on deadlifts and tbh I quite like the way tehy feel
