Yeah, sorry getting a little clogged here with so many settings, tests, etc.
This is my best score with settings included... Thank you for your patience...
Intel Core i7 2700K running at 4.5GHz/1.28v
8GB Corsair Vengeance 1866MHz running at 2133MHz/1.6v
EVGA GTX 780 Ti SC running at 1250MHz/1.150v (MEM set to 2000MHz/8000MHz QDR)
Any tips on how to push further?
SLI?![]()
Thanks.
Turn off hyperthreading on your CPU - it will run more efficiently and does not need the extra threads in Heaven.
Make sure you are running windows basic to reduce vram workload.
RAM speed makes very little difference in this bench and overclocking it can even have slightly negative results.
