- 20 Dec 2007
- Nottingham
I've not found the charging speed whilst using the laptop to be that bad when using the supplied cable, it certainly hasn't discharged. However the cable is very short, so when using various longer cables instead, it has charged much slower to the point where it is using more power than the charger can supply.
It's not fast charging, probably a good 4 hours from totally flat to fully charged using the supplied charger and cable, but under my normal use the battery will last between about 7 and 8 hours.
Normally just use an extension lead now when i need to, and if i'm taking it out i'll ensure it's got a decent level of charge.
Installed xbmc on it a couple weeks ago, works really well, and video/picture quality is excellent when watching 720p streams.
