Got it wrong was about 3 weeks but dont think it's accurate either...was comparing it to last measurements though some things can cause it to change whilst being measured.
Can anyone answer what i posted though please?
Even training same muscle groups with different exercises on the day after?
Sun:Triceps/Chest+15min HIIT
Mon:Biceps/Back/Shoulders+15min HIIT+Str Cardio
Weds:Triceps/Chest+15min HIIT+Str Cardio
Thurs:Squats/Benchpress/Deadlift/Some legs.+10min HIIT
I think you might want to get a bit more arm work into your routine. You accidentally did some deadlifts and leg work on Thurs - maybe replace that with some more bench/curls?
True good point, my arms need improving, started doing pushups often too and bicep pulldowns.(dont know name of this)
I keep hearing/reading that working muscle groups twice a week is very good that's why i was thinking of sticking with what i am doing rather than changing to the mentioned example i posted.
Just seen your post Delvis, thanks that gives me better guidance and will go with what you say if others agree though i seen your log you seem to know your stuff.
gained 3kg muscle aswell as losing 0.7% fat over 2 weeks
Yeah it seems wrong, i was 68kg muscle when i started now says 73kg so no idea what's happened with it since last measurement lol.
I been training 4 months now...but still getting into some things and want to try do the best i can.
Just got back from gym, got measured and gained 3kg muscle aswell as losing 0.7% fat over 2 weeks....not bad considering i ate a load of crap for a week or so during xmas so i am happy.
Done a workout of: (bare in mind my weights are low as i am new)
Seated Rows close grip 35kg 3x8
Tricep Bar pulldowns 17kg 3x8
Bicep Curls 18kg 3x8
Lats Pulldowns(think it's called that, overhead pulldown to below chin) 35kg 3x8
Bent over rows 20kg 3x8(i can do a lot more on this but first time i do it so)
Dumbell Chest Press 10kg each 3x8 (can do a lot more on this but my leftside is weak and getting form better for next time)
Standing Dumbells Lateral Raises 8kg each 3x8 (again leftside weak needs catching up so doing a weight it's feeling good with)
Was this a good workout of exercises? i am trying to workout each muscle group area on each day(do compounds on thursday with legs) i go but problem is i go mon/weds/thurs/sun so two days are next to each other twice so might be best just go back to split workouts for them?
Before trying what i did today i splitted over 3 days with 3 exercises or so per muscle group only problem was one group as only being worked out once a week.
I was thinking might be best for me:
I might just go with what you say Freefaller but i am wondering if the above could work well or stick with what i tried today?
Forgot to say, my main purpose is to be lean and pretty solid with around 10%-12% bodyfat or so.I want to put on some mass but not huge amounts.I also should note that i was born with a deformed lefthand which has had 2 operations on it to fuction a lot better though my grip with it is not as good as right....about 70% or so of it.(it's getting stronger and better)
Tom-e: Yeah it was, even though inaccurate it's a lot more accurate than other ones i've used but still i'll just get measured via callipers and take photos now.
UV: I'll do compounds twice a week then few days apart, thanks for the advice.
MrthingyX: I can't do one chin-up at the moment mainly due to my leftside due to what i said about my lefthand.(it's definitely improved)
I work my legs once a week with about 4 weight exercises, started pushups last few weeks, leg raises and will start dips the coming week.
I'll check those guides out thanks!
Yeah i know it takes time, my muscles been building slowly and i am trying to get my form correct on everything before going high weights too.
Pulldown exercises i am doing fairly well with and will try do more of those to help with the hand, thanks for this.It sucks being at a disadvantage but it doesn't stop me.
I think i might do pushups 2-3 times a week with dips to help with benchpress?
Also for my HIIT i am usually doing 15mins with 2mins rest/1min intervals:
Bike 70rpm 2mins/Intervals 1min 125-130rpm resistance 4
Crosstrainer 90rpm 2mins/Intervals 1min 140-160rpm resistance 7
Treadmill Speed 8 2mins/Intervals 1min Speed 13-15
Rowing machine i aim for a distance in 5mins....this tires me a lot perhaps i should do it a lot more.
There is nothing high intensity about those intervals. You need shorter rests and much more intensity, in the 90+% range. The whole point is that you're completely destroyed after HIIT. What you're currently doing is just phases with slightly different intensity, which is just interval training.
Let's go right back to basics with your routine and cover some basics.
You need to be working from a foundation of squats, deadlifts, bench press, overhead press, and some kind of pulling movement (chins, rows, etc.). This is where you need to be spending most of your energy, and the first three or four need to be on their own day (more advanced routines can mix things up).
Secondary to these are your accessory movements, which is also where your isolation work comes in. RDLs, DBSS, more rowing, core work, leg press, shoulder isolation, arm isolation...
