Hi all , just ordered the MSI R9 290 , i aint a big overclocker but would like a tiny boost like 1100mhz on gpu , what would the safe clocking be at stock voltages ?
Thanks
how do you make it so it doesn't stay at 1077mhz when exiting a game? the only way many of us can get 1077mhz is the unofficial overclocking mode, so you have to hit reset in AB to lower back to normal clocks. Have you found a way for it to auto lower the clocks when finished gaming?
Hi, these are the settings I use and with this it stays at around 300mhz on desktop and 1077mhz in game. When I exit the game it now goes back to 300mhz.
I tried setting the core voltage a bit lower, but if I select -25 it goes back to -12 when I click apply lol.
Is this only affecting msi cards or does it affect other brands too?
Having got the temps down a bit and a stable oc of 1080/1400 on stock volts and playing battlefield 4, i decided to flash my vtx last night and put the Asus DC II oc bios on from the 6th december 2013 so stock clocks are now 1050/1350 so not far off my stable oc for gaming, so if i forget to set it, then its not really an issue.
Think im going to keep the card and wait for either more pennies and or an arctic accelero hybrid or kraken to appear to get the noise levels down a bit more.
Would love to water cool but the initial outlay is quite substantial really.
msi 290 non reference ?
im running
core 1100
memory 1400
stock volts
runs fine but you need to do the nonsense afterburner fix listed at the front of this thread
It effects all cards, use this work around to bypass it.
AMD emailed, told them to programme into the drivers that throttling should only happen at either 94c or at a temperature set by the user in overdrive.
What are your idle temps now?
got mine today, DPD driver, i missed delivery and on tracking it said neighbor signed for it and door number was 40 doors away , all the way down the road , how is that a neighbor anyway went and knocked and thankfully had it and gave me it , it was asking for it to be nicked ,
anyway i loaded MSI afterburner and on 1100mhz and 1400mhz memory what does that translate in memory **** ?
also why is it default at 977mhz , when i thought it is pre overclocked at 1007mhz does that mean it has to be done via software ?
Thanks
