Stop using that msi app people thats probably causing the throttling issues if it won't let you increase the power limit.
I've never used it and I still get the throttling issue unfortunately.
Is there a way to find out what memory is onboard without using the card or taking the cooler off (I am at work)? I can partially see one memory module which reads;
SK.....
H5G.....
ROC...
Aye but that probably doesn't help matters allow people to overclock without increasing the power limit.
Have you tried an older driver to see if it occurs there?
http://www.guru3d.com/files_details/amd_catalyst_13_11_beta_9_2_(13_250_18_november_7)_download.html
I started playing dishonored this morning and according to msi ab the core never went above 850 and gpu utilisation fluctuated every second or so from 70% down to 5% and back again. Silky smooth 60 fps though whilst playing so wasn't unduly worried
Edit: forgot to mention have 1150 set in ab with plus 50 power target
I gave up on overclocking mine. Its now sat at a constant 1030Mhz. I had it at 1080mhz but had a power cut and it dialed back.
I don't like how I have to disable YLPVS or whatever it is just to get decent frames in less demanding games. My core clock was dialing back to 600 ish Mhz O.o
Has anyone found if switching BIOS's helps OC Stability? On the stock "UEFI" BIOS I cant even hit a stable 1100 Core at stock volts
