so the aoc 29inch is worth getting, plus can i do this on one gtx780 connected via the display port,how is the build quality on these as i heard the bezel are a little flimsy, plus what do you reckon is the sweet spot, res and hz which is easy to get for a novice, plus would the LG version of 29 inch i think model ea93 or something be a good buy as the max hz in description says 56hz-75hz
Yes it says that but that only means max 75hz at 1280x1024 same goes for my other monitor it says a high 85hz but will only do that in the none native resolutions.
but you can force with custom res util a native res of 2560x1080p @75hz
without the popup.
with the popup and a fix to get rid of it you can get a 3.5k resolution of 3440x1440p @60hz sync`d....
i would also suggest if you only want to add 75hz as the max i would recommend adding 72hz for judder free 24fps bluray playback
but if you do want to add the 100hz then you dont need to add the 72hz as 100hz is a multiple of 23.976 anyway or close to it
i have tested the 100hz mode out in a few games and movies and there silky smooth and that goes for 75hz aswell.
and displayport is fine as thats what i currently am using.
this monitor is perfect for movies and internet and outstanding for games that support the res.
and the picture quality
@native in games is fantastic, i highly recommend dishonored as your first game to test as that game supports the 21.9 aspect ratio and also select 100hz fov in game settings
the monitor i got does not have any issues what so ever i thought at first i had massive backlight bleeding but its not at all, from what people say its called IPS glow. and its not bad at all to be honest and does not affect me on pure black screens anymore as i found in the service menu backlight settings
one other thing that im going to test out i beleve this monitor can do 120hz @ native but only by using dual dvi as i think this monitor is limited in pixel clock via displayport as the hardware it uses is using displayport 1.1a spec wich has a 330pixelclock mhz limit.
and the patch thats out there at the mo does not remove displayport limits only dual dvi and hdmi.
further testing to commence when i find my dual dvi cable...... havent used that type of cable in a age lol
