 - 4 Nov 2011
There's a few of things that you could do.
The first being reload. Drop the weight on the sets and work your way back up.
OR Drop the weight and up the reps, so instead of 5x5, maybe try a 3x8.
You could also try doing 3 sets at a weight where you can really get the form right and then 2 more sets at what your working weight should be.
You can also try doing 3x3 of your working weight and then do an additional set for lower weight but as many reps as possible/just more reps.
 However, do not hide from a poor motor pattern on barbell bench, as this will only get amplified with dumbells if you are not careful.
