Snakes, I bet it was snakes.
A highly unlikely theory at first glance, but I've heard a lot of stories...
They've published 3,200 sq km of images. The South China Sea is 3.5million sq Km.....(I know, I know, the plane will be a lot more localised, but still)![]()
the most dire circumstances.
anyone managed to load the images??
What is the reasoning behind searching the new area, hundreds of miles from where it was? Turning back wouldnt put it two hours away would it, with no radar contact inbetween?
surely if the plane hit the water at a certain angle it could disappear in tact without out trace, fuel wouldn't leak out for a while
You're not the only one asking that....
"Malaysian civil aviation chief Azharuddin Abdul Rahman, whose agency is leading a multinational effort to find the Boeing 777, said the search includes northern parts of the Malacca Strait, on the opposite side of the Malay Peninsula and far west of the plane's last known location. Azharuddin would not explain why crews were searching there, saying, "There are some things that I can tell you and some things that I can't."
Make of that what you will....
I'm fairly certain that at the speed the plane would have been traveling, hitting the sea would have been the same as hitting solid ground, and it would have smashed to many many pieces.surely if the plane hit the water at a certain angle it could disappear in tact without out trace, fuel wouldn't leak out for a while
