Knocks and a harsh ride
Thanks for the pic Kaka. I assume it needs to be upside down to match up with the correct terminals. Is it a tight fit or is there enough space to stuff a couple inline fuses down the side?Fitted one a few months ago. Not had any problems with it and fits in the tray fine.
Mine's exactly the same and on a windy day, watch your head (same goes for bonnet).I'm curious as to how far other people's boots (hatchback) open when you press the button - mine doesn't make any effort to open at all, it just sits on the latch, and the boot is quite stiff to open and the struts don't really hold it up if it's anything other than fully open.
I thought new struts was all you needed for automatic full-open. Let me know how it goes and what parts you ordered. Oh and lots of pics pleaseSo I'm going to replace the gas struts but I'm wondering how much of an improvement there'll be in how far it opens on its own without doing the "spring mod"?
Will the button inside the car open the boot while on the move?
