Sounds like the SE is for the thinking man then
[TW]Fox;26033341 said:Not on a 335 Coupe.
[TW]Fox;26033012 said:The M Sport premium is quite bizarre. It's annoying because M Sport cars do look good but in the case of the E92 you are often paying thousands of pounds for what is quite literally a steering wheel thats £250 on Ebay and different front and rear bumpers.
It's the same with F10's - an equivilent M Sport is often £4-5k more than an SE with Dynamic Pack (Which adds sport seats, black headlining, etc etc). £4-5k more for..two plastic bumpers and some alloys.
Did see a perfect LCI 335i M Sport saloon at a local dealer a few months ago, wasn't so happy with the 21k price tag though, ouch.
JB4 and BMS DCI ready for the weekend
http://www.koenig-felgen.de/ have very competitive prices, and they're local
Get the F1 Assy 2s. Excellent tyres. Just because you've only got 150bhp doesn't mean you won't have to perform an emergency stop from 140MPH..
Nothing like referencing a post made almost 18 months ago
I'm looking to get a bit more out of my F21 125i, and the JB4 is appealing because:
1) It doesn't cost anywhere near as much as the M Performance Power Kit (~£350 vs ~£1125) The MPPK is literally an ECU swap, with no intercooler upgrade as I originally thought.
2) It provides more BHP and torque than the MPPK, and is easily removable.
3) If I install an MPPK, I may battle to sell the car because the prospective buyer might be put off by the increased insurance premiums.
The only thing that the MPPK has over the JB4 is the warranty support.
Was your JB4 reliable? Did you have any problems with the car after you installed it? Did BMW ever pick up that you had it installed?
Thanks
EDIT: I just found this which makes some pretty big claims, but I can't find many reports of people using one of these.
, bet he got that idea from Nissan (GT-R). At least could have modded a grille in there so it looked like it should be there instead of simply screwed in place randomly.Snip
Unrelated........ I know you've done this, so would you recommend using a magic eraser for dulling a shiny steering wheel? Or is it more likely to start me down a road to needing a retrim...
