And it's here...my new Ducky Shine 3 Limited Edition (red switches). An absolute luxury given my setup but the lack of LED on the Filco was the only negative or thing that annoyed me (a Filco with RGB LEDs would be nirvana I think).
Initial thoughts in comparison to the Filco are:
The red switches will take a bit of getting used to because they are so light. But overall happy so far with the keyboard and as ever and the brilliant services from Overclockers UK.
I've had the FUNC 1030 L for just under a year, replacing an old 7-year FUNC pad. Really great mouse surface. Use it with a Roccat Kone XTD although part of me wishes I stuck with an optical mouse.
- It's about the same weight (very slightly lighter).
 - Slightly more angled upwards than the Filco, to the point the F keys are about another keycap in height higher.
 - The LED back lighting isn't as prominent as the normal Ducky I expect but it's good enough.
 - The Ducky has better grips and therefore slides far less easily
 - The build quality is exceptional (as it is on both).
 - However the PBT plastic keycaps on this Ducky are lovely. Really nice feel to them.
It's really helped rekindle my love for FPS games, I've also ordered the new version of the fUnc Surface 1030 and will probably pair it with a Mionix Naos 7000, should be quite a nice setup!
 Sorry to treat you like tech support, but what's the bets keyboard I could get for around the £60? Will be used for gaming and also a lot of typing, so I'm leaning towards blue switches but I think browns might be better overall.
